Guest Anonymous Posted April 18, 2003 Share Posted April 18, 2003 I think I want to replace the long neck in my 68 with an LSD from a 320is. I found one from an 82... what needs to done beyond swapping for a later subframe and dealing with the need for shimming the output flanges a bit? Thanks, Jan Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 18, 2003 Share Posted April 18, 2003 new set of half-shafts. Ditch those old needle-bearing joints and go to the CV joints used in later models for the outside joint. Check the archives or the FAQ and decide if you're going to use spacers and 320 inside joints, or new diff flanges. Replace your driveline guibo also. John N Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 18, 2003 Share Posted April 18, 2003 Thanks John. Jan Quote Link to comment Share on other sites More sharing options...
