Guest Anonymous Posted April 18, 2003 Share Posted April 18, 2003 I have about 35k on a rebuild I did on engine, added 5 speed, and went through entire car. Anyway I drive 135 miles every day and during this time the engine's average oil consumption is 1 Qt a week. I have JE forged pistons with total seal rings (9.3:1) The compression is 150 PSI across all four. Has anyone else had similar oil usage experience with forged pistons. by the way the car runs very strong with a solex 1 barrel. I use 10/40 Wt Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 18, 2003 Share Posted April 18, 2003 They require a special different sunnen stone. Many people just finish a cylinder with a AN-301 stone. That's what gives it that nice cross hatch.. The total seals need a smoother finish of a AN-501 stone because of how they're made and you can even goto a cork stone if you have time. That is part of the reason total seals get a bad rep for not sealing or burning oil etc. Switch to 20w50 castrol and toss in a bottle of STP oil treatment and see if that helps. Check for leaks as well. Party On Kris Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 19, 2003 Share Posted April 19, 2003 (nt) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 19, 2003 Share Posted April 19, 2003 My car has same setup,doesn't use as much oil but has a bad problem of smoking at idle.Does your car smoke at all? Quote Link to comment Share on other sites More sharing options...
