F/S Ireland Wilwood 300mm 4 piston BBK non-tii
This is the Big Brake Kit with 4 piston radial mount calipers. Minimum 15" wheels. Used for less than 1k miles. Bearings are great with mobil 1 grease. Includes hubs, wheel studs, SS brake line, wilwood calipers, 2 pc rotor, brackets. Everything you need to mount them. This is a single brake line caliper.
Putting my tii back to stock. Email for images and photos
Located in SOCal
$850.
Dracoruno@gmail.com
Ray,
This BBK will not clear 14" wheels to the diameter of the 300mm rotor and calipers. It has no relation to the offset of the wheels running spacers. This requires a minimum 15" wheel. Can not run anything smaller. If you want the other BBK using e21 rotors and 528 calipers you can run 13" wheels and up.
If you need other details Ray just give me a jingle and I can go over with you.
Thanks,
Le
626-497-3773
