Guest Anonymous Posted April 17, 2003 Share Posted April 17, 2003 how do you remove the knob for the vent windows? i was going to try to tackle it this weekend if i get a break in the action. also does anyone sell a kit w/all of the bushings to rebuild the shifter for a 4-speed? or do i just have to get them seperatly? as always thanks a ton, Dave Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 17, 2003 Share Posted April 17, 2003 URL: http://www.2002faq.com/engine_and_drivetrain/shifter_rebuild.html (nt) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 17, 2003 Share Posted April 17, 2003 sweet!! thanks neil, and steve k. did you source it from the dealer ok, or did you go through paul or someone else? you guys rock the house! -dave Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 17, 2003 Share Posted April 17, 2003 For the window crank, you need to remove the round plastic cover that is inserted in the knob . IIRC (I am at work and the car is at home), it has a small tab or hole so that you can pry it out. Then the rest is just removing the screw in the center and pulling it out. For the shifter bushings, give Paul@Max a call and he will get together a kit for you. That's what I did for mine. HTH, Harry Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 17, 2003 Share Posted April 17, 2003 the knob. NOT a screwdriver like all the POs did... Damn POs. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 17, 2003 Share Posted April 17, 2003 URL: http://home.earthlink.net/~nharren/index.html I would call Paul@Max, I am sure he can hook you up. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 17, 2003 Share Posted April 17, 2003 You should see a small circle or "dot." This indicates where the hole is on the back of the knob (use a mirror to confirm this). I bent a hook into a metal coathanger (or you cound use an Allen wrench or cotter pin puller) to push the insert out of the knob as you pull on the hanger. If the knob is already boogered up, use the screwdriver to pry! John in VA '74 tii Quote Link to comment Share on other sites More sharing options...
