Magnetic Valve black/white
chat66
Can I bypass (eliminate) the black/white magnetic valves?
-any serious consequences by doing so
Would like route vacuum advance from distributor
to manifold vacuum, where the white magnetic valve
is currently routed to manifold vacuum.
Also, would like to eliminate dash pot, on Carb.
Yes, I am eliminating smog/emissions.
No negative if you are desmoging the motor. Just make sure you use the nipple on the manifold, not the carb, to go to the distributor.. If its a late car, here is my experience with harness..
http://1leadshoe.blogspot.com/2011/02/smog-harness-removal.html
As a rule of thumb, vacuum advances use ported vacuum. Thats the port that is above the throttle plate on the carb. It only comes on when the throttle is open. If you use manifold vacuum your timing will be advanced during idle resulting in driveability issues and a crappy idle.
Earl
74 02Lux
02 M roadster
72 Volvo 1800ES
Earl
Crap. I totally brain farted on that. My bad. Thanks Earl.
Earl
No sweat...I got your six....
Earl
