Guest Anonymous Posted April 17, 2003 Share Posted April 17, 2003 This will probably sound silly but my interior dome light has quit working. One of the two bulbs has always been burn out and when the light stopped working I assumed they were both gone. Put in replacements and still no light. Used a test light to check circuit and no light. Checked the fuses and they are all okay. I'm at a loss. DB Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 17, 2003 Share Posted April 17, 2003 (nt) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 17, 2003 Share Posted April 17, 2003 1. Remove plunger switch on door post 2. depress the plunger with your finger and you'll notice four little sharp prongs on the back side of the switch. These touch the switch frame when the switch is on (pushbutton out) and ground the dome light, thus completing the circuit. 3. Clean prongs and the spots they bear against with a little sandpaper 4. If the screw is rusty, replace with a new stainless steel screw. The switch itself grounds thru the screw. Cheers Mike Quote Link to comment Share on other sites More sharing options...
