SoCal Vintage is Here!
Post your photos!
Problems getting the strut out of the strut housing.
bkerr
The drivers side was easy, but I am having no luck on the passenger side. I removed the cap that locks the strut in place, but there seems to be a metal spacer that has fused itself to the strut housing making it impossible to get the strut to come through the cylinder. I've tried heat, prying with screw driver and ice pic, and clamping the entire top of the strut to a vice and pulling on it. Any advice or suggestions appreciated.
it's not a spacer - that's just the top of the shock insert
tube -
try CAREFULLY heat from a MAP gas hand torch-
warming up the top of the outer strut housing -
large channel lock plyers gripping the insert and twisting
it free
if this car has had any impacts? - the outer tube housing
might be bent and your inner shock insert will never come out
Just one of a million things that we can't tell you on this
long distance guessing game show.
YES - DANGER!!!
that's why I said CAREFULLY!!!, DO NOT HEAT THE BOTTOM
of the strut housing - that might cause a rocket launcher
effect depending whats trapped inside the housing between the insert?
so please just heat around the threaded top of the housing
possibly drill a 1/8" hole about 3" down from the top of the threaded area
to drain out any nasty fluids that are inside there.
Wear PROTECTIVE GLASSES, BODY ARMOUR, AND KEEP THE SMALL CHILDREN & FARM ANIMALS AWAY AT A SAFE DISTANCE INCASE
SOMETHING GOES REALLY WRONG!
