Guest Anonymous Posted April 17, 2003 Share Posted April 17, 2003 upgrading headlights, stereo install, dash ground wire fix, electric fuel pump, etc. what size electrical wire should I get? colors? red= constant power red/white= power from the ignition brown= ground what else? TIA, Jack Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 17, 2003 Share Posted April 17, 2003 As I said over there... 12 awg. is more than adequate for most of the big power consumers, except for stereo amps. For amps, it just depends on their capacity. For small consumers like fuel pumps, 14 awg is adequate. If you want to get scientific about it, check out one of the many wiring voltage drop tables available on the web. It all depends on how much power a device consumes and how long the wire run is. Personally, I think red and brown are good enough. All you really need to do is distinguish between + and -. Chris B. '73 ex-Malaga Quote Link to comment Share on other sites More sharing options...
