upgrade alternator/wire
What do you guys did when you upgrade your alternator? I noticed the original red wire from the stock alt. is a thin wire (maybe 10-8 gauge)I just added an Amp for my stereo/H-4 headlights/fog lights.I want to replace it with a 4 gauge wire direct from alternator to battery. What do you do with the original red wire? Do you install it back to the alternator or dont attach it? Thanks Rae>>>>76 02
unless you upgrade your alt. over 100 amps. And, if you install a 6 or 8 awg. wire, there is no reason to also use the original wire.
Chris B.
'73 ex-Malaga
