Guest Anonymous Posted April 16, 2003 Share Posted April 16, 2003 I hope one of you 02ologists can help me out. I was changing both heater hoses in my 72 project car when I noticed build-up on the tube that exits the manifold and feeds the heater box on the drivers side. So, I got out my strusty little wire brush and srubbed it... it crumbled! I have a hole in the tube the size of a penny and the rest of the outlet tube doesn't look very solid. Hopefully this is pressed or screwed in and not a permanent tube. Can I fix this? Or as I expect, I need a new intake manifold. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 16, 2003 Share Posted April 16, 2003 what carb are you running? Stock manifolds are a dine a dozen. you should not have problmes finding one. steve k Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 16, 2003 Share Posted April 16, 2003 I am running a 32/36. I have calmed down now, but my voice still hurts from yelling. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 16, 2003 Share Posted April 16, 2003 you might be able to clean out the hole, tap the opening with a 1/2" pipe tap and thread in an aluminum fitting to replace the old hose nipple (the 1/2" dimension applies to the inside diameter of the fitting - the tapped hole is actually closer to 1" in diameter). Earl's Supply should have the fitting you need - can get them through Summit Performance if no one in your area carries them. I used this proceedure to modify the outlet hose fitting on a manifold last year, worked fine. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 16, 2003 Share Posted April 16, 2003 just post that you are looking for a 2 barrel manifold and you will most likely find one. Ask Sam, he probably has a couple hundred of them steve Quote Link to comment Share on other sites More sharing options...
