how do I replace the clutch return spring in the pedal box?
Mine seems to rotate instead of acting like it should, plus it just looks nasty, so I want to replace it. Where should I buy one and how do I go about replacing it.
thanks,
robin
1665200 and one after. The early one is a plain old spring hooked to a bolt on the pedal box and is the same as one on a 1600; later ones have a torsion spring wrapped around the pedal shaft.
Cheers
Mike
VIN 1670068 - just wanted to know if there were any tricks or secrets that would make it easier. Can you replace it without taking the pedal box off the car?
robin
