Sunroof is back in...IF YOU DO THIS....
If you do, save yourself some time and energy and do this: If you have to completely remove the roof and sunroof headliner, then that's where I can help. The rest is fairly easy. To reassemble, just remember or take pics like I did. The only problem was putting the cover back in. I found that by completely assemblying everything but the cover, then removing the two corner sections and two of the three screws and loosening the third one holding the side sections down I could lift up and slide the cover in from the top. Remember that it goes in the grooved sections. Good luck. When you get ready, e-mail me and I'll talk you through it on the phone at the critical point. Like I said, everything else just takes time and patience, but the cover is a PITA.
