Headlights no workie....
URL: http://www.02fanatic.com/modules.php?set_albumName=album05&op=modload&name=02gallery&file=index&include=view_album.php
Hey all,
Because it's such a wonderful day today, I've decided to do some work on my beater 75. It seems the headlights don't work. I have no power at the lights, or at the fusebox. This includes the low and high beam circuits. I replaced all three relays because I have spares, and I also tried another switch. No go. Before I dig out wiring diagrams, and start troubleshooting this, anyone have any idea?
Thanx,
Al
If all compents (i.e. switch, relay, fuse, bulbs) it has to be
wiring. If the grounds are good, check the wiring at the critical
places, where they are likley to rub metal and ground out.
Nothing is gonna work if the battery is missing or dead. Also try running +12 directly to a headlamp using clip leads. After you verify a good source and a good load, should be a matter of following the wires.
