Guest Anonymous Posted April 11, 2003 Share Posted April 11, 2003 (nt) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 11, 2003 Share Posted April 11, 2003 URL: http://home.earthlink.net/~nharren/index.html Triangles are to access the hood bolts when closed, round ones??? Dunno. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 11, 2003 Share Posted April 11, 2003 URL: http://home.earthlink.net/~nharren/index.html (nt) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 11, 2003 Share Posted April 11, 2003 The 2 triangle holes are for clearance issues with the hinges. Don't think the hood will shut without hitting otherwise. The 4 holes are for drainage. If you notice there are ribs that are for increased strength (on either side of the hole) but without a hole, water would stand... So there is a hole between each area that could potentially collect water. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 11, 2003 Share Posted April 11, 2003 triangles to clear hood mount bolts and allow for lower nose/hood; holes to drain water. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 11, 2003 Share Posted April 11, 2003 access to bolts enabling propoer alignment of hood when closed (access is done with the grills off). Round holes are for paint, primer and water drains. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 11, 2003 Share Posted April 11, 2003 with the hood closed, round holes with edges flanged down for drainage. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 11, 2003 Share Posted April 11, 2003 four round holes are for sticking screwdrivers in while yer werkin on it..;p -Rob Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 11, 2003 Share Posted April 11, 2003 The round holes will swallow up all hardware up to 15mm. Most hardware is 10 or 13, that's why there are more small holes. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 11, 2003 Share Posted April 11, 2003 BTDT. Used to carry half my tools just behind the fire wall along with a bottle of water and oil. Just enough for oil change, tune up, engine removal or, major transmission overhaul. yup. Then they got rusty... Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 11, 2003 Share Posted April 11, 2003 great minds think alike.................. Quote Link to comment Share on other sites More sharing options...
