Guest Anonymous Posted April 11, 2003 Share Posted April 11, 2003 why does my oil light,the amber one, come on at low revs then go out once under acceleration on my 73 tii? everything seems to be running properly. how does one repair this? dw Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 11, 2003 Share Posted April 11, 2003 URL: http://www.bmw2002faq.com/cgi-bin/talkrec.cgi?submit=lt&baseurl=http://www.bmw2002faq.com/talkshop/forum&msg_num=54649 (nt) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 11, 2003 Share Posted April 11, 2003 in the morning on the inital start the light should go out within 3 to 5 seconds if it takes longer it may need re-blueprinted to bring it back to factory spec. And do not assume a off the shelf one is even close to specs eather they will do but they could be better. If the light does go out in time, check the motor to ground and body to the battery if they are good replace the oil sencer. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 11, 2003 Share Posted April 11, 2003 a failed pump... how old is the motor mileswise? -Rob Quote Link to comment Share on other sites More sharing options...
