Locating a steering wheel
worzella
Anyone know of a website(s) where I can enter my '02s year and get a list of steering wheels that can be used? I am leaning toward a nice wooden model versus the original one or the small diameter replacement that the PO put in mine.
Might be a dumb question, but I am not sure of what "specs" I need to follow
for a '75. Is it as simple as the correct "spline" match and associated lock down bolt.
While I am showing my ignorance, what about the horn ring? Will the one I currently have work with any new steering wheel?
Thanks,
Randy
Thanks a bunch... Found a million wheels on this site and this nice explanation of the adapter kits they sell too.... Crowders Customizing....
Randy
Nardi/Personal Steering Wheel Hub Adapter Kit - BMW 1600/2002/Tii - Thru 1976 - Part # 4302.14.0601
* This replaces your factory steering wheel, then you can install any Nardi/Personal steering wheel to your vehicle. All the instructions and hardware are included with this product. Includes hub adapter, screw kit, hex key wrench, horn ring, and any horn wires you will need for for vehicle.
* Brand new in factory box with all hardware. Made from the finest high grade aircraft quality steel & aluminum.
* This adapter hub will fit most 6 lug Nardi/Personal steering wheels with a bolt pattern of 2 7/8 inches or 73 mm. Made in Italy.
* This hub adapter fits: BMW 1600/2002/Tii - Thru 1976
