SoCal Vintage is Here!
Post your photos!
ok... how much are these things worth out there?
Trying to put a prince on these and can't find a precedant. Any suggestions out there?
Roman
Further to my previous postings, I've finally taking the struts out of my car and posted their photos on the followings link:
http://picasaweb.google.com/roman.lysiak/TiiStruts#
The bilstein dampers are shot. Their carcasses might be able to be rebuilt or you'll need new ones. Seals were totally gone. Struts have been bent to 2 deg. I came up with that number with a bit of triganometry: over a distance of 257mm, I found 9mm of pitch = 2 deg. Posted photos show the difference between the stock ones I picked up and the ones in my car. I also included a dimension of the cut strut to the base of the welded plate. Also, there are a few shots of the springs, and the markers inscribed into the tops of them. There are two labels on them: 10CS220 and 10.0. I'm not sure what these mean but I'm assuming 220 is the spring rate?
Offers welcome for the struts and springs: roman.lysiak@gmail.com
Thinking that it costs 1K to buy a set of stock tii struts and it would likely cost around 500 to have the work done. So I was thinking around 500.
Roman
