Guest Anonymous Posted April 8, 2003 Share Posted April 8, 2003 in desperate need of new suspension. I want the best of all worlds. I do primarily very spirited around-town driving & the roads in Atlanta, as elsewhere, aren't the greatest. Am planning to use Bilstein Sports with Eibach dual-rate springs and combination of rubber and polyurethane bushings. Plus k-mac camber plates and front and read strut braces and larger sway bars? Also will have 15" BBS with 195x50x15 SO3's. Any comments on this set-up are welcome. TIA Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 8, 2003 Share Posted April 8, 2003 Well...I have the eibachs and the sports, along with 195/60 14. I also have fresh rubber bushings and probably wouldn't recommend urethane for a daily driver. There are days in I wish I had the HD's in but most of the time it is just about perfect... Ryan 68 02 Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 8, 2003 Share Posted April 8, 2003 I love the ride. I have urethane everywhere and really don't mind the ride. I also run 185/50/15 and love the handling of the car, cruising and throwing it around corners. Brian 76 02 Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 8, 2003 Share Posted April 8, 2003 All depends on how tolerant you are of a very tight suspension. I run almost that exact setup: Eibachs, Bilstein Sports, 195/50-15s, urethane all around, f & r strut braces, larger sway bars. The ride is very controlled and miles away from a worn-out stock suspension. If you are willing to feel every last pebble and twig in the road, to have almost constant low-level road vibration and to exercise considerable care around potholes, you'll be fine. The handling is excellent, feel is wonderful, but it is not even remotely similar to a stock suspension, even one that's brand new. If you are having second thoughts at this point, I would suggest Eibachs, Bilstein HDs, rubber suspension bushings, larger sway bars, and strut braces. Just know that everything is a trade-off. If you really want the best of both worlds, you're probably better off buying an nice new M3. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 8, 2003 Share Posted April 8, 2003 Ryan, did you get your alternator problem fixed? I have a spare. G Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 8, 2003 Share Posted April 8, 2003 I have Bilstein HDs, Eibach Pro-kit springs, ST sway bars, all urethane bushings and 185/60/14 tires. Overall, I think this setup is a great compromise suspension. My last 02 had this same setup sans the big sway bars and urethane bushings and I actually thought it was not-quite-agressive enough. But sway bars make a BIG difference on these cars. Now, the only thing I will do is get fixed front camber plates (and borrow the R compound tires for autocrossing from my other car). My 02 is a nice weather driver which sees occasional autocross use and I want to retain at least an inkling of its ride quality. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 8, 2003 Share Posted April 8, 2003 i use bilstein sports and h&r springs. the combination is outstanding. i also use a strut brace.jack fahuna recommended it as well as a local racer. they were very accurate in that it serves well for street and as i have track time in other cars i know that this set-up will be fine there too. dw Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 8, 2003 Share Posted April 8, 2003 My tires are 185/60-14's and ride is stiff. I really don'y mind much, since it is my fun car, but in a daily driver I would install Heavy Dutys with the Eibachs. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 9, 2003 Share Posted April 9, 2003 I run Bilstein HD's and Eibach sport springs along with Maximum Stick 25mm 22mm swaybars. I find the ride is very controlled and not too harsh. Minsoo 1973 Inka 2002tii Quote Link to comment Share on other sites More sharing options...
