clutch master line installation
Codfish
Hi,
now that it is cold weather in philly,
i have done two of these in the past
month. i also have one more job coming
in for the same thing. so, when the clutch
master is out of the car, you should remove
the filler tube from the car and install it
to the top of the master and also attach the
hose from the master to the slave. this is done
because it is easier to do on the work bench
than on your back. reinsert the master by
snaking the fill tube up from the bottom
and then getting one bolt in loose from the
bottom of the pedal box. it sounds complicated
but is very easy if you bungee the door open and
reach both sides with your hands. be CAREFUL
about threading the master and slave ends into their
parts because they cross thread very easy.
once all the bolts are in then reattach the large eyelet
to the pedal. if you have the metal large eyelet on
the old cylinder then transfer it to the new
master because the aluminum ones break often.
good luck
stone
When you said "Hard to do with the clutch master being mounted" I smiled and got to work...Thank you !!!
Like NCB said above, loosen the clutch master so you can rotate it a bit, that son of a gun tube/line will go right in then. Hard to do with the clutch master being mounted.
I did this... Well just about the same thing...(I saw this post after I completed the job) Thank you !!!
I love this place !!!
Hi,
good luck
stone
