Clank and wiggly stick
Biemenstien
Shifting from first to second getting a lot of grinding and now a pretty good clank and some push back on stick.
First thought...Transmission
Second...Clutch. (it was replaced with engine about a year ago.)
Got all the feet in the air and climbed under while helper started car and shifted through gears.
drive line, guibo, universals, all look ok.
get some bucking from the trans when shifting out of 1st and when 2nd engages.
Your thoughts
Thanks.
