Rear hub nuts are STUCK!!
I can't get the rear nuts broken loose. Tried liquid wrench, heat, hammers, chisels, and cussing. The cylinders are turning over b/c of the tourque being applied to the nut. Any suggestions?
Byron
76 02 inka
3ft breaker bar with a 6ft chain link pole extension.. if possible you should stand on it... nothing has ever resisted the breaker bar with the extension.
if you can't shift 'em with leverage, you get to drill 'em off.
I'm about 5 for 8 on getting them off intact. They can REALLY bind solid...
