SoCal Vintage is Here!
Post your photos!
carb question
mikea
you guys were all quite helpful when I was putting my new weber 32/36 on
I had jetting questions... bottom line- I installed with the mystery jetting from weberdirect and it seems fine- idles rock solid etc.
today drove about 200 miles- Bay Area to Jenner CA & back beautiful day.
question: on downhill with the engine in gear
i often get a lot of black smoke out the back.
i have mixture screw adjusted for best idle.
it's only on downhill / deceleration I get this smoke
any ideas
we're talking about '74 2002-weber 32/36- vacuum adv dist.
then i'd try leaning it out and readjusting the best idle...someone else may be more help...i know very little other than what i've figured out from my own cars
as i understand it, you get the fuel/air mixture right then adjust for best idle...
i've had a lot of webers and never look'd at jetting or even knew what jet were in them but they all run very well and i change them around from car to car....i always have to futz with the mix and idle anytime i swap from one to another car
....then it's either your float level too high ?
or the usual worn valve guides and hardened valve guide seals
have someone else drive your car down hill and
you follow in another car to observe the real
smoke story........
any chance you can tell us WHAT the jet sizes are ?
PRIMARY IDLE=
SECONDARY IDLE =
PRIMARY MAIN=
SECONDARY MAIN=
PRIMARY AIR CORRECTION=
SECONDARY AIR CORRECTION=
FLOAT LEVEL
DOWN mm=
UP mm =
HOW DID YOU SET THE IGNITION TIMING ? =
c.d.
thanks for your help
I had set the ignition timing as per your recent recomendation
( w. adv hose disconnected at 1500 rpm )
i will figure out what those jet sizes are, but in the meantime i will adj the valves.
can you tell me the correct intake & exhaust valve settings?
thanks
