SoCal Vintage is Here!
Post your photos!
6v questions 1967 1600
well............... if you have a 12 volt battery in the car now?
it's running we assume?
look at the label on the alternator, and voltage regulator
it should read
either 6volt..... or 12 volt and other data
remove a headlight bulb and look at the
markings on it - 6 , or 12 volt ????????
the wiring changes with 6-fuse, 12-fuse cars,
and changes a little over the years
They did not go to the 12 fuse panels until 1971 all 6 and 12 volt cars had the 6 volt fuse boxes until then. The heater fan, gauges, lights starter and charging system are the reall big issues (I know that is just about everything. ) The 6 volt systems usually had generators not alternators. Unless you have found a time capsule I would guess it has already been converted to 12 volt by now.
