SoCal Vintage is Here!
Post your photos!
76 Hose Routing
steven_4u2nv
the hose from the valve cover was attached to the bottom of the original air cleaner...it pumped the oil blowing off of the engine thru the carb...re-burn...polution
most run it to the ground or to a catch can to prevent pumping sludge into the carb
I run mine to one of these...
http://www.summitracing.com/parts/STF-5115/
Or you could also go with the little K&N breather filter...
like this...
http://www.summitracing.com/parts/KNN-62-1330/
Or you could just route the sucker down towards under the car to add some fine Brittish Undercoating to your car.
What ever you do DO NOT PLUG THIS HOSE... It will blow your valve cover gasket and make messy...
BD
