Stainless Steel Hardware
rshivley
I am in the process of replacing the injection pump belt on my '73tii. I just finished cleaning all of the little rubber chunks from the old belt out of the outer housing or cover. I noticed several of the different bolts have some rust on them. Would there be any advantage of replacing these bolts with stainless steel hardware? This would be the bolts for the fan belt pulley, the injection pump belt outer cover, and the bolts that secure the air cleaner to the inner fender.
TIA
Rob
