for a 5 spd equipped car...... clutch slave cyl is from
jrkoupe
yup, perversely, the smaller diameter clutch is thicker by 5 or 6 mm....
use the 320 throwout for the 215 320 clutch.
(it's all in how the pressure plate is built)
Yes and there are 2 different 228mm pressure plates.
The higher 228mm pressure plate needs the some TOB as the 215mm clutch.
As long as you don't use the longer TOB with a high pressure plate you'll be fine.
