SoCal Vintage is Here!
Post your photos!
Got a Microsquirt setup today
nbristow01
Anyone using a Microsquirt out there??
Picked up my injection system and my buddy handed me a DIY microsquirt system. We will be setting it up to run my 318 EFI on my 02. I have a dist getting built at advance distributors. For now we will let the Micro run the distributor. Once we get it running good we will be adding a crank trigger and distributor free system with 4 coil packs. Also using bigger injectors and 325TB. Its still cheaper than buying a new dual carb setup and should be a lot more DD friendly. The Microsquirt has already been set up to accept a sensor so I can run flex fuels with no power loss. Also it has been setup to run a ping sensor if I want it
I see you have the 45s FS...
just wondering what was unacceptable to you about this set up..
I run 40s, and altho she only sees 2 or 3k miles per year, I find her overall very drivable. I mean, I will get some throttle tip in lag...or some sputtering at times below 2500 rpm.....but its quite minimal. I do see yours is a DD.
Feel free to e me.
Oh I sold the 45's. I should have kept them and the cannon intake and made an ITB system but oh well. I drive my car about 2000 miles a month so the EFI will be really needed. I get along fine with the 38/38 but you still have to tinker with carbs. I would like to be able to drive to higher altitudes without it running like crap also. With the EFI, Microsquirt setup I can dial in best performance and run flex fuel when that stsrts getting more common
