Fuel Line into K-Fish Bolt - Install Question
cxzsaq
Looks like you need to clean those threads before installing the bolt.
Whatever you do, don't run a tap into the hole pushing debris into the pump!
There should be a copper crush washer between the bolt head and banjo fitting (Y-pipe) and a 2nd one between the banjo and KF pump. Rotate the Y fitting so that the main supply line from the fuel filter doesn't hit the air cleaner snorkle.
