Tii Wiring Question
cxzsaq
I have an extra wire (solid green) coming from the Time Switch which I cant figure out where it goes!
Its very short (as seen in the photo).
Can anyone suggest where this connects to?
The wiring diagram I have is not clear as it says it connects to the fuse box (11).
does it have a clear rubber shroud covering the terminal?
if so, is the rubber shroud very clean compared to a typical engine compartment electrical connector?
if it is very clean in comparison, i'd be willing to bet it connects directly to your fuse box (underside, of course).
i can confirm by looking at my in-op tii if you don't get a definitive answer before then.
Damn! I think you are correct! its clean - or cleaner than the other wires. But i could swear that i never took wires from the fuze box. So then this just connects to fuze 11? i hope theres a plug underthere. Thanks again!
