Speedo cable for 76 2002 w/320i 5 speed
I may need a new speedo cable. I hear the common replacement is a 2002 automatic one piece cable. I have looked at partsforbmws.com and am confused by the picture and part name. The picture shows 3 cables. An upper and lower cable-I think this is the 4 speed set up. There is also a third cable for $65 that is called a drive shaft. Is this the one piece automatic trans cable we use in our 320i 5 speed conversions? In addition are there other sources where we can buy the one piece automatic cable??
Thank you jdm. I will keep this in mind. With more research I have found that the $65 cable on Maximillion's site is in fact the automatic one piece cable I might need. I will reinstall my origional cluster with a dead odometer but good speedo soon in order to locate the problem part. Presently I have neither functioning speedo or odometer. If I need a cable I will most likely go new because installing a new cable is involved and I do not ever want to do it again. However what state do you live in and how many years of service would you guess your cable has on it?? Thank you for your response and interest.
