Sign in to follow this
Anyone using this Walbro Fuel Pump?
3 posts / 176 viewsLast Reply
URL: http://www.jcwhitney.com/item.jhtml?ITEMID=4665&BQ=jcw2
Does it work well? Noisy? Thanks for your help....
WALBRO® ADJUSTABLE PRESSURE ELECTRIC FUEL PUMP
Built-in regulator pre-set at 2-1/2 psi—can be adjusted from 1-3/4- to 5 psi pressure rating
Prevents excessive fuel pressure buildup on sensitive and high-performance installations. Pump operates only when carburetor needs fuel; float movement regulates fuel delivery. Built-in screen filters out debris. Use with gasoline or diesel fuel. Not for fuel injection. 22 gallons/hr flow rate. Female inlet/outlet: 1/8"-27NPSF (National Pipe Straight Fuel). Includes mounting hardware, instructions. Size: 6-1/2" H x 2.38" W x 2.52" L. For 12-volt systems.
the guy that I bought my old webers from sent me a bunch of stuff, and with it he sent me two older versions of those, like really old. They looked pretty much like that, but I don't think it regulated on its own, but yeah, i never used them because they never worked, to old ya.
But, somebody used it on an 02
Bryan
red73
(nt)
