74-76 Rear Center Bumper Shock-FOUND
  • 5 weeks later...
After you take out bolt #5 (on the diagram), you'll pull out the bumper shock and sometimes the plastic insert comes out with it. If it doesn't then you can pull it out by inserting an "L" shaped "hook" into the round hole and yanking it out (a similar motion as a slide-hammer). Sometimes it takes a little coaxing, but it will eventually come out. Do you think you have the center bumper shock as well?
Thanks,
