1602 rear half shaft swap?
MAP
Has anyone swapped haft shafts on a 1602 (longneck Diff) with 320 half shafts?
I did read some posts about drilling the flange?
Thanks HBChris on the write up about early shaft boot replacement but as it turns out my shafts are worn out.
Any help would be apprciated-trying to advoid swapping subframes or differentals.
