5-speed conv.-shorten driveshaft by how much?....
The six bolt guibo (for 3 bolt flanges) is thinner than the stock 8 bolt (4 bolt flange) guibo, thus requiring a longer driveshaft.
one which is exactly the same as an 02 one, or the later E21 6-bolt guibo, which is a little thinner. If you need to know for the 6-bolt one, e-mail me and I will measure the respective thicknesses.
Gil
72 Tii
+ 16 other cars in and around the garage now. Yikes!
doesn't it make sense that the driveshaft should be shortened by exactly the same amount. Elementary math! If a measurement shows another figure, then there is something wrong with your car, like maybe it has been collision damaged, rear subframe mounts are rusting away, etc. Don't forget that the diff. is mounted on slotted holes if you need to fine tune things.
IMHO, the measuring thing is an urban myth. But it can't hurt just as a check to see if something is indeed wrong.
Gil
72 Tii
