Massive BBKs (fr + rr) only available thru GBs from now on.
I am sad to anounce that I will not stock anymore of the front and rear 2002 kits. My last production of 15 front kits took a whole year to sell. Therefore, it's not economically feasable to see money sleeping on shelves. Kits will be available to shops at wholesale for a minimum order of 5 sets too.
I will produce front or rear kits only when I have 5 confirmed orders. Production is 3 weeks. The front kits is with floating 300x32mm discs, while the rear race-only kit is with 300x21mm discs. No more handbrake for the rear. Race-only rear kit.
The front kit with 300x32mm floating rotors is $1199.00usd + pads
The rear kit with fixed 300x21mm rotors is $1099.00usd + pads
If you want to join the group for a production of front or rear kits, simply add your name below and specify what you'd want.
Thanks
Lee
Front 300x32mm kit (yes, I know, the bolts are too long - just for mocking up though)
Rear 300x21mm kit. No handbrake produced. Race-only. Kit is available with Dynapro (1.00" pistons) and Superlite calipers (1.12" pistons).
Hats are available in black only. Short braided lines are included. Welding of the steel stubs is recommended. They are currently with 10mm thru holes. But you can redrill them to 12mm or 1/2" and thread them. The calipr adapters are now machined from aluminum and anodized black.
