Guibo innards
duckdudess
While browsing my parts manual today I noticed that the drive shaft guibo appears to have innards: shown as parts 1-8 on 26/6 of the parts manual. When I replaced the guibo 1 year ago, I didn't see any of this stuff as the guibo fell apart in pieces when I removed the drive shaft. I simply bought the new rubber guibo, insterted it between the output flange of the transmission and the flange on the drive shart and bolted them together. Could I possibly be missing this stuff or is it inside the transmission output flange ? If missing, wouldn't I notice it , assuming it has some function ? Help!
without any pictures - I assume your refering to the centering bushing
and grease seal that belongs in the front end of the drive shaft-
which keeps the shaft centered, supported, and lubricated
onto the output shaft end of the transmission.
The rubber guibo does not have any innards.
YES - those parts are important!
i LIKE coax in my windshield strip, thank you very much.
I spend the $55 I save on new parts that keep the wheels on!
(heh)
Seriously, CD, I have NEVER seen that heat shield on ANY car...
of course, the exhaust manifold heat shield's almost always missing, too...
