SoCal Vintage is Here!
Post your photos!
High oil pressure on new engine.
mp1k3
Hello Everybody, I have a little problem with a new engine. When I first start it up the oil pressure is 100 lbs. If I rev the engine too much the oil filter seal will burst. If I let it idle for a few minutes the pressure drops to 80 lbs and all is fine. Any ideas?
First off, your new engine won't be new very long revving it when cold. This is for the same reason your oil pressure is high at startup- cold oil is too thick. The high pressure indicates it's too thick to pump properly, and regardless it's not doing any lubricating whatsoever. Revving the engine in that condition is causing excessive wear.
Second, what oil are you using (brand and grade)?
I recall the same symptoms when doing bearings, oil pump and rings on the Tii. Believe I had the oil pressure relief valve spring backwards which consistently blew the filter gasket and made quite a mess. You'll need to drop the pan and pull the oil pump to see if this is the problem.
