SoCal Vintage is Here!
Post your photos!
rear license plate
mo's72tii
Does any one have a fix for the two holes next to the US license plate lights other than fill and paint?
I do not like the euro holder with a us plate (sorry if the pix is your car).
Also has any one moded a license plate bracket that sits below the rear trim that connnects the tail lights?
Tangentially (?) you can install license plate lights in your bumper, as shown on that Euro tail. Those shown are the same as the E9 light assemblies I do believe.
I suppose if you were inventive you could place the lights atop the bumper and secure them. This does not specifically answer your bracket question but... I guess I like to type!
Cheers,
Ray
little plastic plugs that have metal faces. You can clean/polish the metal faces and clearcoat 'em, and that's the factory look. They are there because that's the standard Euro plate attachment point.
As for mounting the US license plate: I've always mounted mine using the bottom two holes in the plate, and placed a 3/8" thick rubber washer between plate and body. That keeps the plate from touching either the between-the-taillight trim on a roundie, or scratching the paint on the little lip that's just below the license place. Works for me.
cheers
Cheers,
Ray
Thanks Ray. I have eliminated the side lights and have euro lights in the bumper. I just forgot to fill those and paint them at the time.
cheers
Thanks Mike....I have a license plate frame and will probably need to fab a bracket to work. I want the finished plate and frame to be below the trim piece on the 72.
I have some touch up to do so I may fill and paint those holes.
