differential seal change
///mChris
I have a e21 LSD that is leaking pretty badly.
I've noticed that the input shaft seal is NLA from real oem.
Does anyone have a good source for these seals? How about part numbers?
I have done my several hours worth of searching, but have not uncovered any good info. Maybe we should put together a FAQ page for this purpose.
Thanks
Edit... Of course I found the part number immediately after posting.
If I take photos of my seal replacement.. Can I have it posted as an FAQ?
1968 BMW 1600 US VIN 1560713
manufactured on October 2nd, 1967
http://mybmw1600-2.blogspot.com/
I would second having it up as a FAQ, as I certainly would like to see how you do it. I'm planning on having a few diffs laying around to change out as necessary depending on the track the car will be at. As such, any added tips for diff maintenance/rebuild are relevant to my interests.
Cheers,
Ian
1976 BMW 2002
1961 Austin Mini
1983 BMW 320i
For E21 seals and bearings, especially the later, larger bearings,
RockAuto has been a decent source.
CD's posted procedure is valid, but you have to be REALLY careful
not to increase the crush on the sleeve, and that's not easy. Best would
be some sort of 'ring wrench' that would let you see the edge of the nut
and the end of the shaft as you tightened it...
One other thing- if the bearings are worn or out of adjustment, that kills
an old seal. And it will kill a new seal, too...
Having said all that, changing the bearings isn't an impossible job, if you
have a press and a way to make a couple of pressing arbors...
what I've found,
  • 1 year later...
