SoCal Vintage is Here!
Post your photos!
85mm Linkage Setter prototype
shipm_8
While cleaning the garage, I bumped into a baggie of ball studs, another baggie of acorn nuts and a few brackets I had hoarded for this project. Here is my first shot at a prototype for a 85mm linkage setter, home made version:
Close up of ball stud:
and comparison with original BMW tool, p/n 88 88 6 135 040 aka 13 5 040 aka 6071
Hello Armond...Now that I know these ball studs work, and that I can make this without injuring myself, I may try to make one for the accelerator linkage (289mm).
Jim, how did you know? Pepe is the shop supervisor, yes!
I'm out of the bearing kits, but have a bunch of the M14 nuts, and happy to put a stamp on one or a handful of them if you'd like. Here are the parts for a kit if you'd like to round them up next time you make a virtual trip to McMaster-Carr.
2ea 5909K14, Cage assembly for 17mm shaft dia steel needle-roller thrust bearing
4ea 5909K74, 1mm thick washer for 17mm shaft diameter, needle-roller thrust bearing
1ea 91280A784, hex head cap screw, M14, 45mm, 2mm pitch
1ea 90576A120, nylon-insert locknut M14
Distinguished and serene pose. Could it be because I had a biscuit on one hand and the camera on the other?
Thanks William! Will fill up my basket at McMaster-Carr.
