Battery trunk relocation options
rey949
13 hours ago, MoBrighta said:
Why did you?
Most folks don't like the stock location for many reasons,  Here are a few.
1) All that weight (original batteries) so far from the center of mass;
2) Vulnerability -- in a frontal collision, a punctured battery likely means no driving home.
3) Handling -- nose-heavy on the left side is unbalanced; equal load at each corner is better.
4) Maintenance -- having less stuff under the hood makes almost everything easier.
5) Weather protection -- freeze-bake cycles, wetness, road crap, oil fumes, antifreeze, you name it, it's bad for a battery.
6) Envy -- E24 Sharks, M cars, high-zoot models have their battery in the trunk, must be for a good reason.
7)  How do you make a car faster and more reliable?  "Add Lightness and Simpli-cate."
Hope this helps, but I have probably overlooked about 42 other good reasons.
You added lightness with a 3 lb. battery, right?
II moved mine under the back seat, doing the "cutout a flap / welded in box / thick cable to the starter" model.
Similar to the way uai did, I even had a 106 liter fuel tank in the same location he did - not factory, custom.
For two of your reasons: lightness and to get it out of the engine bay. But I never considered putting an Anti-Gravity in the engine bay until after I had already run the cables to the back seat. I wasn't aware of them at the time. If I was, I would've done that with a new type of battery mount. Reduces engine bay clutter, saves all that cabling and still subtracts 30+pounds.
1974 2002 Tii-SOLD
1978 911SC Coupe
1988 Landcruiser
2020 M2 CS
