Sunroof winder spring
Vic
been awhile since I had mine apart, but IIRC there are a couple of grooves on the handle's shaft that the spring fits into. I think it's kind of intuitive when you remove the handle from its shaft by unscrewing the machine screw in the handle's center.
Hopefully the broken remains of the old spring will be there to guide you.
cheers
