SOLD: 228mm Flywheel - Surfaced, 17lbs.
Here's a just-surfaced 228mm flywheel. It weights 17 pounds, which I believe is lighter than stock (not sure on that spec (?)). The ring gear is in good shape, though it does look like a couple of teeth met the starter once (I had this flywheel on my street car and it always cranked fine). Many cars with the 5 speed conversion use a 228 flywheel and clutch setup, as do the later 02's. Some folks prefer it for higher-power cars.
