SoCal Vintage is Here!
Post your photos!
Lost Key
pmtinsd
inside of the door lock cylinder (requires removing the handle to read) here are a couple of other options:
1. Remove the steering column housing so you can see better, then look up under the dash at the housing that holds the ignition lock. If you're lucky, there will still be a little paper tag stuck to the housing with a letter followed by a 4 digit number. That's your key code. If there's no sticky tag, look on the inside of the steering column housing. The adhesive may have lost its stickiness and the tag fell onto the housing.
2. If no tag, you can carefully drill out the roll pin in the ign lock housing; then pull the ign lock cylinder assy out and take it to the locksmith. He can easily make a key from it.
3. Or you can remove a door handle and take it to the locksmith (this presumes your door and ign locks are the same, as per the factory)
FYI--have several spare keys made to avoid this grief in the future...
