Painfully slow wiper fix....Will it work?
Ok I have reviewed all the threads in trying to fix my super slow but functionally wiper so I have removed the wiper assembly and freed the motor and taken of the back of the big round gear that is powered by the worm gear:
BEFORE I PUT IT BACK I want to cover all of my bases::
A couple of observations:
the gear looks clean but the grease is old , a little dry
the threads say add new grease, a couple drops of engine oil or something equivalent...is that all there is too it?? (too clean out the old seems that it would be impossible)
UPDATE:
GREASE ADDED Cover replaced is there a way to test it w/out putting it back together
Also the pivot points seem to have a fair amount of play...does it matter? and if so how do I snug it up w/out replacing parts?
ALL help greatly appreciated
KEVIN
PS I have looked in Haynes, Resto guide and workshop manual
70' 1600 Malaga
75' 2002 polaris 91-95
2000 328i 95k
2003 GMC Envoy-stolen and replaced
2010 GMC ACADIA
1996 Dodge Ram 1500 247k
The wiper mechanism in the 2002's is tough to remove around the heater fan. I took mine out while working the heater box.
If your pivots look anything like mine did, then plan on getting another used assembly or replacing ALL the parts.
The left and right pivots are different and don't come with all the hardware.
Here is the motor pivot shaft
And the (2) rods that connect the motor to the wiper arm pivots
jgerock-
thanks
I have been following a UK how to:
I took the motor from the assembly
took it apart, cleaned and greased
now the motor doesn't work at all
if the ground on the back of the motor is attached to another(different) screw could this have caused/the stoppage it cant be the wire connectors b/c they are color coded
Any Ideas??
It was working great forever
then got slow month ago
now I tried to fix it...
70' 1600 Malaga
2000 328i 95k
2010 GMC ACADIA
I tinkered enough over the last 48 hours and I am convinced that even though it was operable when I removed it ....it now is no longer
I'm in the market for a new one
thanks for the help
70' 1600 Malaga
2000 328i 95k
2010 GMC ACADIA
