FUEL TO FUEL PUMP ON A 72
DONK
Can anyone tellme if thereis an electronic fuel sending unit that delivers fuel to the mechanical fuel pump on a 72 02? It seems like no fuel is being delivered to the fuel pump because no fuel is visible in the clear fuel filter. The fuel pump is brand. Was working b4 i tried to rebuild the carb
Don
Check the screen on the bottom of your fuel sender, it may be clogged.
-Nathan
The fuel sending unit on a 2002 is a twist-in cylindrical item.
Disconnect the battery!, remove the fuel line and wires, then twist the unit until it releases from the tank. Pull it out and examine the fine mesh screen on the bottom of the unit. Chances are it needs to be cleaned/replaced.
i pulled the sending unit and cleande the filter. The tank was bone dry-leads me to think there is a leak in the tank. When I actually drovew the car I p ut 20 bucks in and drove it 40 miles and have since put a gallon or two in it it and only droveeit around the block. If course when I pulled the sending unit the filter fellinto the gas tank
