Clutch wont bleed
ERIC02
Hi everybody, just finishing up my M20 swap and cant get the clutch to bleed. I am getting fluid to the master but none past and the pedal when its pressed just falls to the floor. The master was installed a month or two before i bought the car by the previous owner and worked properly before. But I have had the pedal box out for over a year. i have used the search function and i am not missing anything. i am stumped! Iknow its probably something simple but any advice would help thanks in advance.
Eric
need a pressure bleeder from the top res.
or
an oil can 'pressure bleeder' from the bottom bleeder
pedal method won't do it
do a "search" - millions of discussions about it
'64 R27 250cc #383851 18,000m
The same happened to me and here's what I did.. Let it sit with the reservoir cap off over night.. should have full pedal in the morning (the bubbles go out on their own).. found this out after i had my car towed home at 2am.. Bled and bled for hours, then had to get it towed, got in it in the morningm and have been driving it since.
Thats my experience..
Zac Cardinal
1972 2002tii's Blog
1976 2002 "Margie"s blog
