TII Accelerator Pedal Assembly
cxzsaq
1, 2, and 3 secure the pitman arm (15) to the firewall support (17). If you are talking about the connecting rod between the pedal box and the pitman arm you want to look at fiche 35/10. In this, clip (3) secures rod end pin (4) to the pitman arm. For some reason I cannot add an image, so check the other fiche on real OEM.
Fred '74tii
--Fred
'74tii (Colorado) track car
'73tii (Fjord....RIP)
Fred '74tii
fred. if you can email me a photo, that would be awesome. you are correct - i did need to look at 35/10 as i have no idea what # 3 and 4 in 35/10 look like.
I don't have a photo handy but there is a good schematic at this link:
http://www.bmw2002faq.com/component/option,com_forum/Itemid,0/page,viewtopic/p,714545/highlight,/sid,bf080cf799b8a9718bd06ed2df45d538/
The "pin joint" sits atop the threaded rod--it should be adjusted such that the Kugelfischer pump lever almost touches the pump stop screw when the accelerator pedal hits the throttle stop on the pedal box (inside the cabin). If it is not correct either you will put too much pressure on the throttle linkage when going to full throttle (by hitting the pump throttle stop before the pedal throttle stop), or you will not get full fuel and air when the accelerator bottoms on the pedal stop. If this does not make sense then you need to learn more about the system. A good place to start is the original Kugelfischer manual and video at:
http://2002tii.org/kb/59
See page 16 of 29, it has the picture you are looking for and describes adjusting the linkage.
HTH, Fred
--Fred
Fred '74tii
Fred, any chance for that photo?
