Rear Camber
ClayW
What is going on with my rear suspension? It has a set of Ireland Stage 1 springs, no swaybar and some probably worn out Bilstein Sports. I don't have that much in the trunk and I'm getting quite a bit of negative camber back there. Will a new set of Bilsteins HDs help?
ClayW
It is likely the Springs. The design of our semi-trailing arm suspension is that as you lower it...it gains negative camber quite fast....faster than e30 for example.
I doubt the bilsteins will change much as they are a damper not a spring...but I am sure if you added some high pressure KYBs they may add some buoyancy to your rear :) Either way you need to have proper shocks in the rear.
You can add a slotted subframe kit (requires removal of subframe) which will allow you to dial out the neg camber.
Look at the subframe mounts....they are not perfectly symmetrical from top to bottom. By flipping them (rotate 180 degrees) you can raise the subframe slightly which will take out some of that neg camber.
Clay,
Add the Billies and an ST rear sway 22mm and a front 19mm and all should be good.
The 1600 looks great.We ought to toss a little photo and get together soon with the local characters.
A brisk Rock Creek Park drive or more substancial,all ideas are welcome.
Jonathan
1973 Malaga "ti"2.3 stroker,dual 45s,lots of Alpina content13x6 Superlites bilsteins,Petri Sport ,GTS Seats,Coco Mats,Old Man Style "Patina"....but the old Emily is Fast.
2010 GTI 200 H.P.,dsg ,18"wheels etc.modern daily driver.
Clay, did you leave in the lower pads? As you probably know, there are 1,2, and 3 "dot" pads that are of varying thicknesses. Maybe you can raise the rear a tad with a thicker pad, which will dial out a bit of the -camber.. I have even read of others reusing the aluminum spacers from the front to raise the rear..?? K-Mac offers a urethane eccentric swing arm bushing to dial out -camber, but I have never read a review on how well they work.
EDIT: UPPER pads.. Thanks CD.
(O=o00o=O)
yep, unless you have the adjustable trailing arm mounts installed, the lowerr it is, the more camber you get. your car is pretty low...too much camber. i adjust the ride height to get the desired camber...2.0 deg in my case. your car is way lower than mine.
2xM3
That's probably where I should start. Should I go with 2 or 3 dot pads?
ClayW
shocks do not control ride height
springs control ride height/camber in rear
should have one of three thickness rubber
seats at the top of the spring
and a very thin rubber at the bottom of the spring
to prevent rusting, noise, insulation
you can subsitute heater hose over the bottom coil
to meet the bottom need
order/scrounge DOT top rubbers
about 1.0 ~ 1.5 degree negative at the rear is nominal
'64 R27 250cc #383851 18,000m
