Yet another transmission question
FunElan
So after getting a good look under my car today, it appears the transmission is sloping downwards (which isn't good for the guibo). However the shift tower is already rubbing against the transmission tunnel. What are my options?
I already have a new 5 speed on the way so hopefully I'll be able to share more once we get the old one out.
Thanks,
Matt
'68 Caribe 1600-1563167
Well, the crank nose IS higher than the diff nose, so there should be
some angle....
If you have the early style tower, there's adjustment in the back rod- more than you might think.
The late style tower should just float with the body...
hth
